85mm MAF on 2000 LS1?
Old 09-18-2007, 01:38 AM
djsanchez2's Avatar
Default 85mm MAF on 2000 LS1?
Would an 85mm Z06 maf fit on my 2000 LS1? I'm picking this up and wanted to couple it with a LS6 intake and P&P TB. Then go cam only.
My main question is, would the pins match upof the connector?
Old 09-18-2007, 07:35 AM
Black99CamaroSS's Avatar
It wont fit like the stock maf did inside your lid so you will need some sort of coupler. You can trim down a 3x3 frenco and make that work. You will also need a 5 pin to 3 pin connector for the maf and you will defiantly need to tune for it or you will run rich.
Old 09-18-2007, 12:27 PM
djsanchez2's Avatar
Cool does anyone sell the connector outright?
I already have a 3" fernco on there. The adjustment for it being rich i can probably do w/ my predator. (well temperarily) I don't plan on installing the 85mm til i got a LS6 intake and have my TB p&p, as i have a Granatelli maf on it now.
Old 09-18-2007, 12:32 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
honestly at this point , with your current mods there really isnt an advantage to do it.
Old 09-18-2007, 01:29 PM
Moderator
jimmyblue's Avatar
You can't adjust it properly with the old version Predator. Do not
know whether the "new & improved" will do it. There is not a whole
lot to gain vs a descreened (unported) stocker. Casper's sells the
adaptor harnesses. But I'd put the money toward a real HP/$ gain
instead.
Old 09-18-2007, 02:06 PM
djsanchez2's Avatar
I was gonna install the intake parts with a cam if that makes a difference. If not oh well i'll have an extra maf, just in case.
If that is true about the predator than it will really have to wait til i feel i have enough mods to warrant a tune.
Quick Reply: 85mm MAF on 2000 LS1?
