Guys with over 800rwhp whats your fuel system
Looking to put to geather a fuel system for the T/A ....for the 800+ rwhp mark...this is a boosted eng as well....
looking for a parts list....
thanks
thanks
LS1TECH Sponsor
Give me a call, I can set you up with a complete system that is proven to feed your engine with a couple hundred extra HP to spare.
It will connnect to your double pumper kit to complete the package.
For more information, I can be reached at (724)322-8505 7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
Originally Posted by daniel6718
what are yall doing about one of them failing? i keep hearing people mention that what if one fails but i dont hear and responses
Originally Posted by RealQuick
What happens if you run a A1000 and it dies under WOT? Same thing. Your fucked no matter what if a pump dies (whether you have 2 or 1).
Originally Posted by Speed Density
I run a Magnafuel 4302 pump, A1000 regulator. -8 Feed and -6 return.
All the goodies too, pre/post filters, cutoff, cooler etc...
Tony.
Tony.
LS1TECH Sponsor
To clarify a few items...
To address Walbro failures, I have been building double pumpers for Racetronix for over 3 years without a pump failure.
As for power capability, I have replaced A1000 pumps, that could not feed the motor, with my Double pumper kits. These have supported well over 900rwhp without any type of volt boosters. The A1000 is usually good for about 800 flywheel hp when it comes to forced induction EFI applications at elevated fuel pressures.
Sumped tanks definitely have their place, but for most applications that are street driven, the dual intank setup is queter, does not require a pump controller on the street & will likely feed most cars well into the 8sec range.
Since Jeremy already has the pump system, there is no reason to change it. Add lines, rails & regulator & it should meet all of his needs.
I have a Ricks stainless tank in my second gen running two gs340 walbro pumps ,the second pump comes on only when fuel pressure drops, done with hobes pressure switch, running two 6an lines to a y block than a 8an line with 6 an return, my ls-7 has 711 flywheel hp works great
You cant see my setup at all, it looks baller.
Ive even got the Twist Loc blue -12 hose to the pump, so it stands out. But you cannot see it from any angle.
Tony.
Tony.
