EGT's on gas turbos
Old 09-20-2007, 09:06 PM
kbracing96's Avatar
Default EGT's on gas turbos
Ok, so I was curious on what kind of EGT's I have on my setup, so I bought a EGT probe that works with my EFILive, since I can use it with the diesels too. I installed the probe inbetween the last cyclinder and the turbo (about 8"). What I'm seeing is a max of about 1500-1550* at the end of a WOT run with both low and high boost (7/11lbs). AFR is good about mid 11's in both. Also spraying meth (well, windshield washer fluid) though a M10 nozzle. Just driveing down the highway seems to be around 1150-1250. Anyone have any thought or input on this? Anyone else watch EGT's? What are you seeing? Here's the log.
Old 09-20-2007, 09:28 PM
LS1TECH Sponsor
DrTurbo's Avatar
That is about right for a gas engine. Typically nothing over 1600degF should be done.
Old 09-21-2007, 10:38 AM
kbracing96's Avatar
Anyone else ever watch there EGT's?
Old 09-21-2007, 08:37 PM
Dbluegoat's Avatar
where did you get the probe?
Old 09-21-2007, 09:43 PM
kbracing96's Avatar
Pegasus Auto Racing. I pmed you the link
Old 09-22-2007, 02:46 PM
kbracing96's Avatar
NO BODY watches EGT's anymore???
Quick Reply: EGT's on gas turbos
