-25cc dish to much w/ 71cc combustion chambers
Old Aug 4, 2007 | 12:43 PM
deadmanTA's Avatar
Default -25cc dish to much w/ 71cc combustion chambers
I'm about to rebuild my short block for boost and found a member on here who wants to sell this for $1100 shipped:
Brand new never used or opened
Eagle 4340 H Beam Connecting Rods 6.125 -
Wiseco Boost Pistons -25cc 3.905 bore -
Wiseco ringset -
LS1 Crankshaft, polished -
My only concern is that I have aluminium 317s (71/72cc chambers). Is my final compression ratio going to be below 8:1? Should I go with this deal?
Old Aug 4, 2007 | 12:50 PM
98transguy's Avatar
depending on thickness of your gasket , .050 thick gasket gives u roughly a 7.66-1 compression ratio.
Old Aug 4, 2007 | 12:52 PM
ddnspider's Avatar
thats retarded low of a CR for a street car
Old Aug 4, 2007 | 01:16 PM
98turbls1's Avatar
Dude just go with some stock ls6 heads or 5.3 heads to bring it back up...
Old Aug 4, 2007 | 01:41 PM
deadmanTA's Avatar
Thats what I was thinking too! Prob. going to pass on it.
Old Aug 4, 2007 | 01:46 PM
Screamin_Z's Avatar
u can mill the heads and/or use a thinner head gasket
Old Aug 4, 2007 | 02:10 PM
ddnspider's Avatar
honestly the heads u have are cheap so id just sell those and get some better heads with a smaller CC
Old Aug 4, 2007 | 03:31 PM
stevieturbo's Avatar
And then use 30psi of boost to make up for the low CR
Old Aug 4, 2007 | 03:34 PM
ba78ta's Avatar
Excuse the novice boosted question.. but with modern day tuning.. why can't you run a 7.XX to 1 blower motor and a large amount of boost?
lack of low end power?
tuning/starting issues?
Old Aug 4, 2007 | 03:52 PM
ddnspider's Avatar
guys are running 20 psi with 9:1 CR on blower car so why kill off idle power?
Old Aug 4, 2007 | 03:57 PM
you can, but with modern day tuning....we do it with relatively high CR's instead, and make more power everywhere.
Old Aug 4, 2007 | 04:02 PM
Josh@KY-Turbo's Avatar
You would need a .040 headgasket and 58cc heads to get 8.5:1. There are alot of people selling great flowing milled heads in the 58-62cc range you could get fairly cheap.
Old Aug 4, 2007 | 05:24 PM
bhz28's Avatar
I am using the -25cc pistons in my 370 and I am using 65cc chambered heads with a comp of 8.7:1 just to give you an idea.
Old Aug 4, 2007 | 07:04 PM
Tom@SpeedInc's Avatar
IMO
I would go with Diamond 11503 -8.6 cc dish, 71cc heads and MLS gaskets.
I'm over stocked on -15 Diamond pistons (p/n 11517 370ci pistons) I could give anyone here a deal if you chose to go Iron block.
Old Aug 4, 2007 | 07:47 PM
deadmanTA's Avatar
Thanks guys, just found a great deal on a low milage 02 motor. I'm going to use the money to get that and get my car back on the road, then I'll have an extra block sitting here to build a boost motor out of. I would love to have a 382 w/ some 225 AFRs.
Old Aug 4, 2007 | 08:41 PM
ls1290's Avatar
Dumb Ass Vette Moderator
A little nitrous to help spool up would not hurt either
Keith
Old Sep 21, 2007 | 08:49 PM
phildo's Avatar
Sorry to bring up a old thread but I am confused. Here is a link to Wiseco who advertises a compression ratio of 8.4 to 1 with 72cc heads. What gives?
Old Sep 22, 2007 | 12:08 AM
DanZ28's Avatar
No linky dink?
Old Sep 22, 2007 | 12:09 PM
phildo's Avatar
My bad.
http://www.flatlanderracing.com/wise...ons-sbc07.html
Old Sep 22, 2007 | 02:47 PM
DanZ28's Avatar
Originally Posted by phildo
Yeah, theres no way thats right! If you leave everything the same and just change the head CC's around like they have, it changes way more than .1 CR. They also show the same CR for different bores and rod lengths, strange.
