TERRIBLE noise!!!
Old 09-22-2007, 09:10 AM
matthewjernigan's Avatar
Default TERRIBLE noise!!!
so i had my oil changed and my tires aligned yesterday.. Later that night, when i go WOT my car makes this horrible sound like two swords hitting each other hard then grinding around.. its commin from around the passenger side area near the front of the car. my guess is when they took my tires off, maybe they put them on too tight/not right? HELP!
also when i gradually get into wot, my car shakes really bad at around 3k then at 4k it makes the sound
Old 09-22-2007, 11:23 AM
Default wow check this out
soooo i get it on the lift and WOW this isnt good.... i think this is called a torsion bar?
note the fifth picture where the e brake cable bracket has grinded away at the drive shaft.... so how hard is it to swap out this part and whats it called anyways?
Old 09-22-2007, 11:26 AM
BANDIT8's Avatar
Dont Sound Good
Old 09-22-2007, 11:29 AM
after some research, this is a broke torque arm !! right?! any suggestions for better ones?
Old 09-22-2007, 08:08 PM
XpEdItIoUs's Avatar
Thats your torque arm just get a aftermarket one like Bmr or spohn. Don't drive it, it looks like it's barely holding on.
