HELP Thumping noise
Old 09-26-2007, 09:17 PM
BLACKHAWK1998's Avatar
Default HELP Thumping noise
After installed new trans, drive shaft, 9” and Spohn adj. torque arm. I started to hear a thumping noise. It happens when the car is going about 40 mph + when I let off of the gas pedal. But quits when I hit the brake or hit the gas. It only happen on deceleration . It sounds like its coming from the drive shaft or where the torque arm bolts up. Any ides??
Old 09-28-2007, 04:44 AM
EPP
EPP's Avatar
Jack the car up by the rear-end, and put jackstands under the axles. This will keep the weight of the car on the rear-end. Crawl under there and see if the torque arm is resting or rubbing on the underbody sheetmetal anywhere. I'm guessing that you find that it is rubbing somewhere around there. A pry bar stuck between the two offending parts will push the sheetmetal in and give you enough clearance to eliminate the interference. Bob
Old 09-28-2007, 08:32 PM
I will look... thanks!!
Old 10-04-2007, 05:24 PM
did find anything.....
Old 10-04-2007, 05:36 PM
i was having this problem about a year ago...
Originally Posted by BLACKHAWK1998
I broken tailshaft housing on the dyno replaced it. installed a Spohn Adj Torque Arm Front Safety Loop now i have a very bad vibration above 90 mph.
one other thing i push it all they way to 120 try to drive out of it and the car acted like it was going to go boom. like the trans didnt want to go any faster the rpms went all the way up to the red line.
So a new motor, Trans, driveshaft and 9" still going on... it starts about 70 now...... HELP!!!!!!!!!!!!!!!!!!!!!
Old 10-04-2007, 05:44 PM
o one other thing i got a new spohn adj. torque arm.
Quick Reply: HELP Thumping noise
