any v6 cars come with limited slip
Friend is trying to sell a rear end out of a 99 v6 firebird, he said was posi. I was thinking about picking it up as a spare. Is there any way short of popping the cover off to see. The car had really low miles, and was one of the nicer v6 cars with the ground effects and whatnot. Also wondering what gears it would have, its an auto. Just curious if anyone had ran across one before, Thanks
it just needs a G80 code. Y87 code is the G80, GU6 i think(3.42 rear) plus the dual exhaust and Z steering. G80 is limited slip.
Mine came one wheel peel style but Im waiting on delivery of my Torsen. Also make sure which carrier it is. If its a 3.08 gear, it uses a 2 series carrier. And a 3.23/3.42 uses a 3 series. You gotta make sure you get the same carrier as your rear.
