Getting my Clutch and Hydraulics done, Check it out
Old 10-01-2007, 08:27 PM
Scammer Alert!
Ricks99ls1's Avatar
Default Getting my Clutch and Hydraulics done, Check it out
ok, i am going to be getting the ls7 clutch, pressure plate and flywheel, roller throwout bearing, new slave cylinder, and the drill mod, done, The problem i was having was spongy clutch, sticking at high rpm shifts and not engaging on high rpm 2-3 shift, my car also has 65,000 miles so i think the clutch needs to be replaced and since i am doing a cam in the next month this was a must, do you guys think this will solve the problems i was having?
Old 10-01-2007, 08:50 PM
Destru6969's Avatar
I just ordered my LS7 clutch kit, slave, & pilot bearing today and I'm doing the install this weekend. I've been having the same problems you're having and I've already done the drill mod and a new master cyl. I think the issues are caused by the old slave cyl. Good luck with it.
Old 10-01-2007, 09:05 PM
Scammer Alert!
Ricks99ls1's Avatar
hey man you to, i am doing mine monday so be sure to let me know would you?
