fuel filter
Old 10-04-2007, 08:14 AM
That_guy's Avatar
Default fuel filter
question do i have a fuel filter in the front and back one of my moms friends said there was one in the front i always thought there was one in the back.
Old 10-04-2007, 09:59 AM
infinitebird's Avatar
no there is only one.
Old 10-04-2007, 10:23 AM
moserman's Avatar
its located at the drivers side right by the door,(under the car obviously) its a cylinder that connects to the gas lines, you cant miss it
Old 10-04-2007, 10:24 AM
moserman's Avatar
unless obviously you are talking about the fuel filter inside the tank, whole different story.
Old 10-04-2007, 11:43 AM
z28hustle's Avatar
the one inside the tank how often do you replace it? i need to replace my fuel pump and i guess if it can/should be replaced ill do it too.
Old 10-04-2007, 12:10 PM
moserman's Avatar
the one in your tank you leave alone until the pump goes... that is merely just a filter to block sediments from the tank from getting into the hard lines. it isnt really the same as the in line fuel filter... but if you are getting a new pump i believe it should come with it as an assembly, if not then i would get a new one while you have it all tore apart.
Old 10-04-2007, 12:12 PM
z28hustle's Avatar
ok thanks again man
Old 10-04-2007, 05:45 PM
Formula350's Avatar
The one in the tank isn't even called, or really considered a filter. It's job is to make sure no BIG particles get through.
Don't be confusing these poor kids
