Please help...air intake problems (codes 171,174 ext lean)..
First off I sold my z28 to my buddy stock w/ free mods, then I just sold him my old k&n, whisper lid, MBA maf ends, baker reducer, and home ported TB.
He keeps throwing codes 171 and 174. Also, I took two readings on the scanmaster and they are very inconsistent one was an 906 and next was a 850! both from 20 rolls.
I checked all the clamps and stuff, all tight.
Here is my list of possibilities,
-Old k&n washed alot and barely oiled(filter is white).
However, would it matter prior to MAF?
-The sensor came off my 2000 SS, it saved work swapping ends of both sensors.
However, I thought 98-00 are the same.
What do you guys think it is?
Thanks for your time, Andy
Re: Please help...air intake problems (codes 171,174 ext lean)..
lean codes are generally cause by leak between the MAF and intake or a leak in the exhaust. If it is the exhaust it normally shows up on just that side.
You can a little electronics cleaner on the MAF and see if the wires are gunked.
Just cleaned the maf with electronics parts cleaner There is however and exhaust leak...The catback was cut by the axle and re-welded but there is a leak now.
