Just got a ls6 intake and..
As the title states I just got a ls6 intake and had a question. Do I have to swap over to the coolant lines a plugs. I thought there was a way around this but I'm not sure. I searched but could only find part numbers for these parts. Not sure if I absolutly need them or not.
The bottom of the manifold won't clear your factory coolant pipes. So you can swap them out for the style that just goes across the front with plugs in the back, or modify the bottom of the manifold to clear your existing pipes.
