Drill mod different on new Master Cylinder models?
Old 10-08-2007, 05:10 PM
tici's Avatar
Default Drill mod different on new Master Cylinder models?
I saw somewhere that the newer master cylinders need a different drill mod procedure than before, ist that true?
The "old" way is to drill a 1/8" hole about 1" deep.
Thanks
Stefano
Old 10-08-2007, 05:55 PM
brad8266's Avatar
Its all the same.
Old 10-09-2007, 09:47 AM
MrEddie's Avatar
The newer masters just have a smaller diameter opening, so it's easier to start with a smaller bit and work up to the final bit.
Old 10-09-2007, 12:22 PM
pddye's Avatar
I used the 1/8" bit on my brand new gm master with line. It worked great.
Old 10-09-2007, 04:15 PM
tici's Avatar
Thanks guys!
I'm installing a new LS6 clutch assembly and new hydraulics.
Is it worthed to make the stock master adjustable?
I did it for the old one because I had an aftermarket clutch (Spec) and shimming the slave wasn't enough.
Quick Reply: Drill mod different on new Master Cylinder models?
