how do you remove a broken power steering pulley?
Old 10-08-2007, 06:24 PM
los bastardos's Avatar
Default how do you remove a broken power steering pulley?
The OE plastic pulley cracked in shipping, I've swapped heads on this motor and all of the pulley has fallen off except the hub and I'm replacing the pulley with a metal one.
How do you get the thing apart? There's an allen screw in the center and I've put a fair bit of force on that and can't get it to budge
Old 10-08-2007, 06:31 PM
ah crap, should have put this in external, sorry.
Can a mod move it?
Old 10-08-2007, 06:38 PM
Randy WS6's Avatar
use this tool, it the same tool for our GM power steering pulley , you can get it at any part store. I used it to changed mine.
http://www.stu-offroad.com/steering/...pspulley-1.htm
Old 10-08-2007, 06:43 PM
ROCNDAV's Avatar
Use the tool that Randy mentioned. You can rent it for free from Autozone (well they make you pay for it, but you can return it after use).
Old 10-08-2007, 06:58 PM
All I have left on the pump is the metal, splined spindle though, and I need to get that off to get my metal pulley on. So that's just a friction fit? The hex bolt in the center does nothing?
Old 10-08-2007, 10:05 PM
ROCNDAV's Avatar
Yeah, its just pressed on. That tool makes it easy.
Old 10-08-2007, 10:06 PM
brad8266's Avatar
Its pressed on, run down to autozone and rent a PS pulley puller for free.
Old 10-13-2007, 06:02 PM
off like a charm, thanks guys.
