Need a 4L80E built. I think????
Any suggestions on who to build my 4L80E? I think it is slipping in 3rd gear. It is like it searches for the gear. Full of fluid and it looks good. Doesn't smell burnt. Is there anything I can check without sending it to be built? Should the converter be checked if there is a problem with the transmission? It is a new Vigilante. If it has to be built, I would like to get it done in the North Georgia area or around Atlanta. Any advice will be appreciated.
Thanks,
SBP
Thanks,
SBP
The car seems to shift fine. But in 3rd gear, it feels like it may be slipping. Or like it doesn't have enough line pressure to hold it in 3rd gear. It also takes longer to shift into 4th gear. If you manually shift the car it seems to do fine if you are on the gas a little harder than normal driving.
SBP
SBP
Ok thanks, let's start with the most recent change. You stated that you installed a new Vig converter.... what was the old converter stalling to and what is the new converter stalling to?
g
g
Well I didn't install it. It was in the car like it is when I bought it. It was supposed to be a Rossler built transmission. After calling him about the problem, I discovered that it isn't. His transmissions are painted black and this one isn't. When I drive the car and it goes into 3rd gear it will pull fine and then it is like it slips and then pull agian and ETC.
Thanks,
SBP
Thanks,
SBP
About the change. It has a TCI stand alone for the tranny. It was fine when I first got it but was a little aggressive for street driving. So I made a few changes to the shift parameters, upshift RPM and downshift RPM. Now this. I don't remember what it was all set at when I got it or I could try and go back to where it was and see what happens.
Thanks,
SBP
Thanks,
SBP
My builder John and I were discussing these symptoms a while ago... his first impression was this is a control problem. After your last comment... I believe it is a programming issue.
Let's start with the current MPH settings... where are they.
g
g
Who can I talk to to help me setup the shift points and line pressure and all? Maybe it is trying to go in and out of overdrive? Maybe I have the shift points to close? Not sure if I have it setup like it should be or not. It does seem to do fine if you manually shift the car and drive it a little harder.
SBP
SBP
WOT Upshift
1 to 2 6100rpm
2 to 3 5900rpm
3 to 4 5700rpm
WOT Downshift
1=25
2+45
3=110
Torque Converter Lockup
Min MPH for TCC lockup=60
TCC lockup rate=60
Lockup Delay=3.0
WOT TCC Lockup
Engine Breaking
4 to 3 = 80
3 to 2 = 55
2 to 1 = 15
Let me know if you need something else from it?
Thanks for the help
SBP
1 to 2 6100rpm
2 to 3 5900rpm
3 to 4 5700rpm
WOT Downshift
1=25
2+45
3=110
TCC lockup rate=60
Lockup Delay=3.0
WOT TCC Lockup
Engine Breaking
4 to 3 = 80
3 to 2 = 55
2 to 1 = 15
Thanks for the help
SBP
Well... unfortunately the TCI module is one of the few I have not learned yet, just have not been asked to get involved with one. If you can send me a link to some online info I might be of some assistance.
Anyone else?
Vince, you ever tweaked a stand alone TCI 4l80E controller before?
g
Anyone else?
g
The fluid is clean as can be. Even though it is clean, could it still be 3rd gear clutch failure? Or what else could it be if the tuning on it is fine and the fluid is clean? Is there anything else I can check or do to help narrow it down? Or just drive it until it totally fails? Really don't want it to completely take a **** and end up buying a rebuild kit and hard parts. Has anyone else not had this type of problem?
Thanks,
SBP
Thanks,
SBP
Well think about it. The problem only showed up after the shift parameters were changed, or at least that is my understanding. So, based on that, I doubt seriously the direct clutches are compromised.
I have not had time to look for that info online. I will try to make the time tomorrow afternoon.
g
g
