Tubular K...
Tubular K...
Hey guys I was wondering which tubular K frame guys with iron blocks are using. I'm concerned that the extra weight of the block might crack some of the lesser Ks out there.
Thanks
Thanks
I'd recomend the UMI, It's built a lil better, but to be honest the #'s that I saw for the iron block lq engines was actually a bit lighter that an LT1 so you should be o.k. These are the #'s that were posted on a post that I found.
Weight in pounds, Fully trimmed:
LT1/LT4: 562
LS1/LS6: 459
LS2: 448
LS7: 458
LQ4/LQ9: 525
LT1/LT4: 562
LS1/LS6: 459
LS2: 448
LS7: 458
LQ4/LQ9: 525
Race your car!
If you put a motor plate on the car and don't run the mounts I don't think it will matter anywhere near as much due to the motor not beign supported by the K member itself.
I am going to add a motorplate over the winter and get a full AJE front end afterwards. it will certainly make mounting a vacum pump alot easier later, as well as a few other advantages.
