Drag Racing Tech
Tubular K...
Old Oct 11, 2007 | 12:53 PM
Supafly1's Avatar
Default Tubular K...
Hey guys I was wondering which tubular K frame guys with iron blocks are using. I'm concerned that the extra weight of the block might crack some of the lesser Ks out there.
Thanks
Old Oct 11, 2007 | 01:13 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
AJE Chromoly, Switching to Burkheart Next Year.
Old Oct 11, 2007 | 06:36 PM
chrismorales75's Avatar
I have some stuff from Burkhart, Chuck was pretty cool to deal with. Post some new photos when you swap the k-member.
Old Oct 11, 2007 | 08:38 PM
bigdsz's Avatar
I have the UMI K member, it has a twin tube that is much stronger, while still keeping the weight down. I jack from the K member regularly with no problems.
Old Oct 11, 2007 | 09:44 PM
01ramair500hp's Avatar
i went with bmr. but i will be running motor plates. not mounts.
Hunter
Old Oct 12, 2007 | 12:30 AM
TwoFast4Lv's Avatar
running the PA
Old Oct 12, 2007 | 02:41 AM
cablebandit's Avatar
bmr...iron block....45000 miles so far...no probs....overall street weight is 4040#
Old Oct 12, 2007 | 04:32 AM
INTENESS's Avatar
I have the UMI with my iron block it is very nice piece and it is double bar.
Old Oct 12, 2007 | 04:10 PM
Vicious95Z28's Avatar
I'd recomend the UMI, It's built a lil better, but to be honest the #'s that I saw for the iron block lq engines was actually a bit lighter that an LT1 so you should be o.k. These are the #'s that were posted on a post that I found.
Weight in pounds, Fully trimmed:
LT1/LT4: 562
LS1/LS6: 459
LS2: 448
LS7: 458
LQ4/LQ9: 525
Old Oct 13, 2007 | 02:13 AM
Supafly1's Avatar
Thanks guys for the posts.
Old Oct 13, 2007 | 07:04 AM
JL ws-6's Avatar
Race your car!
If you put a motor plate on the car and don't run the mounts I don't think it will matter anywhere near as much due to the motor not beign supported by the K member itself.
I am going to add a motorplate over the winter and get a full AJE front end afterwards. it will certainly make mounting a vacum pump alot easier later, as well as a few other advantages.
Old Oct 13, 2007 | 12:47 PM
SiL3NtXWS6's Avatar
bmr with iron block
Old Oct 15, 2007 | 03:18 PM
UMI Performance's Avatar
Our K-member will work just fine with a iron block.
Also we sell them with out the motor mounts when using a motor plate. Just give us a call or send a e-mail and I can help with that.
Thank you!
Ryan
Old Oct 16, 2007 | 08:53 AM
Steve Burger's Avatar
LS1TECH Sponsor
Burkhart and motor plates.
