Trouble Shifting
Trouble Shifting
I have a 95 Z28 M6. The milage is pretty low, about 56,xxx. I haven't had any problems till lately. Now it does not want to shift between gears, and I feel a shaking when it does finally take the gear. It just started last night, and now this morning it did not want to even physically go into first, and I was having problems getting between gears. Any ideas what the problem is? I take care of the car, and it is low milage... I was wondering if it might just be some kind of lubrication issue, but that doesn't seem to explain why it shakes like hell when it takes the gear.
Try posting this in the transmission section hawk,might have better luck. I would say something is going on with tranny,if it was grinding getting in thats one thing,possibly fluid,but if its not going in at all thats a big problem. Also if transmission is shaking check your transmission mount bushing.
Check your clutch resevoir. it is located close to the master cylinder under the hood by the fire wall. it is small, and it takes regular brake fluid. if its not to the full mark fill it up. not saying this is your prob. just making a suggestion. good luck
