URGENT:tranny mount bolt size
The center nut on the transmission cross member is 18 mm.
The 4 bolts on the transmission cross member that mount the cross member to the car are 15 mm.
Which one did you need or did I miss it? I gave all sizes for what socket is need for removal. If you need length I can supply that info but thread and pitch I couldn't tell you.
