Adj Master Cyl benefits?
allows for change of clutch engagement or in certain cituations where you have installed an aftermarket clutch and the clutch doesnt fully disengage an adjustable master cylinder would allow more or less pedal to compensate for the new clutch.
basically its a rod built just like adj suspension parts where you can lengthen or shorten it depending on application
