New LS1 Owners - Newbie Tech - rev limiter
blackonblack02_Z
10-22-2007, 10:56 PM
I have a completely stock 02 Z28 A4. The only thing I have done is cut the factory muffler off and welded in a dynomax bullet in place of it. I am not sure if this is normal but almost every time I get on it in first it will bump the rev limiter before shifting into second. Is this a something that is seen alot?
KENS_SS_4
10-24-2007, 06:46 AM
I can't believe you have not gotten an answer yet. I have a stick but I have not heard about this as a "common" problem. check fluids in the trans if they are good then something is wrong. It may or may not be a big deal.
Try reposting this question in the A4 section.
jmm98LS1
10-24-2007, 08:46 AM
If you're bone stock and bumping the rev limiter on WOT upshifts, you're either low on fluid or your transmission is in trouble. Probably would be a good time to drop the pan for a fluid change and see if there's any signs of significant wear.
question
10-24-2007, 01:48 PM
I have heard this problem before, and I think you can raise line pressure with a tune and it should fix it. Try a search in the tranny section.
SizzlR239
10-25-2007, 07:41 PM
thats not normal ur bans are going because u dont have enough presser for them to snap open
W!CK3DZ28
11-01-2007, 10:12 PM
i have a 2000 z28 with only 40,000 miles thats an a4 and it does that same thing it doesnt go into the solid red but it hits it then shifts and breaks the tires pretty good....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
