shift point
shift point
At what rpm should i shift into next gear?? or At what point will my cam stop making pwer??
Heres my setup, 96 4 bolt main 350, flat top pistons, new rings/bearings/seals/gaskets etc, 1.6 rocker arms, mildly ported vortec heads, valve springs rated @ like 550, 52mm TB, airfoil, stock TPI system, EGR valve was deleted, smog pump deleted, 19# injectors @ 53psi of fuel, walbro 255 intank fuel pump, msd ignition coil, msd dizzy cap/rotor, 160degree stat, shorty headers, 3200 stall converter, shift kit, 2.73 gears, 2.5"downpipe, 3" borla exhaust, 700r4 rebuilt tranny, lighter transmission governor!
these are the specs of the cam:
Duration @ .006 tappet lift 264/269
Gross valve lift .488/.495 with the 1.6 rocker arms its like ~510
Duration @ .050 212/218
thanks
thanks
