malc_p
10-23-2007, 07:47 AM
Hi there - and yes I have read all the stickies about the stereo unit!
I asked this one over on the FirebirdV6 board and got no intelligent answers - seems no-one actually reads the questions before firing from the hip (such as "directly wire the speakers" and so on; read the bit that says the speakers are working) - so I thought I'd ask you guys, who seem pretty knowledgeable (ok obsequiousness overload over).
(94 Firebird V6 3.4, Monsoon 10-speaker system). Yup I know, ancient car, joke engine, but that's another project.......
I've replaced the GM head unit (CD player, graphic eq) with a JVC 4X50W head unit and spliced in the aerial, supply and speaker leads correctly (I've double checked over and again). There are NO spare wires and there is NO amp control wire as on a Camaro. When I swapped the old GM unit back in everything works correctly.
The head unit and the door and trunk speakers are working fine.
However; the sail panel subwoofers are not outputting a music signal but what I do get from them is a continuous "wooooooo", somewhere about the "A" below middle "C" and at very low (but noticeable) volume, so obviously the slave amp is doing something. The tone doesn't change with engine or rolling speed so it's not a bad decoupling problem.
Is this something to do with the onboard slave amplifier not switching on properly? I'm given to understand it's the speaker signal that activates it, SO, is the JVC not somehow giving the right signal level to switch the slave amp on?
Anyone any any clues?
Many thanks.
Baffled Malc.
Many thanks.
Baffled Malc.
