Slow blinkers?
Ungrounded Moderator
If one side works fine but the other doesn't then it's likely a bulb or corroded socket. If both sides have the same problem then it's probably the flasher. Flashers are just a couple of dollars at any auto parts store. It's clipped to the right side of the opening under the dash when you remove the knee panel under the steering column.
On F-bodies (and other cars with 2-pin thermo-mechanical flashers) the side with a burned out bulb will go on but not flash. The faster flashing symptom of burned out bulbs applies to some cars with electronic flashers and many newer vehicles with turn signal control modules rather than standard flashers.
