Windshield Washer Fluid
Old 11-05-2007, 04:40 PM
BadgeZ28's Avatar
Default Windshield Washer Fluid
Yep, adding a meth/water injection set up to a modest boost daily driver. I know straight meth is the best but I would prefer to stick to a mix. I took a look at the local auto store and the percent of methanol was not listed on the washer fluid containers. Just the freeze level. The best I found was good to 20 below. I am guessing colder climates might have lower temp. rated fluid? Anyone know the approximate percentage of meth in the 20 below product?
Old 11-05-2007, 05:32 PM
rao
rao's Avatar
The percentage of methanol is about 38%. I've used washer fluid in my other car for about 3 years. The colder temp fluid has more methanol, but beware of anything that is not blue - you DO NOT want fluid with additives.
Old 11-05-2007, 05:39 PM
allthrotle's Avatar
My friend uses washer fluid mixed with a bottle of iso-heet and he runs it on a roots style charger.
Old 11-06-2007, 02:27 AM
calongo_SS's Avatar
Better off buying straight meth and mixing it yourself than using w/w fluid. It's not going to be consistent from brand to brand, and probably even buying a bottle every couple weeks the mixture will be different.
Old 11-06-2007, 11:00 AM
BadgeZ28's Avatar
I am not sure that mixture consistency will effect me that much? I use a mail order tune and it is safe fat. I am more interested in the cooling effect rather than add more timing or a different fuel curve.
Old 11-06-2007, 11:46 AM
1INSANEGTO's Avatar
Just get the fordmotorsport wiper fulid it has a higher contect then any of the other stuff that is at the store,.
Old 11-06-2007, 01:31 PM
Dumb Ass Vette Moderator
ls1290's Avatar
For the life of me I do not understand why someone will nickel and dime on an gallon of methonal( $2 vs $5 ) on a $5K to $6K FI kit. There is no point in doing a mix unless you are just being a cheap ***.
Keith
Old 11-06-2007, 01:46 PM
BadgeZ28's Avatar
Cheap *** me is using the stock washer fluid tank and driving it year around. I guess I could just meth down the windshield and roof as I drive down the rainy road with a dirty windshield?
Old 11-06-2007, 01:57 PM
ls1290's Avatar
Any good methanol kit will come with its own pump, reservoir, line, and wiring.
Keith
Old 11-06-2007, 02:27 PM
smokinHawk's Avatar
Keith
problem is allot of people dont have methonal sources.
Quick Reply: Windshield Washer Fluid
