Boost setup ?s
Old 11-06-2007, 05:24 PM
wag7079's Avatar
Default Boost setup ?s
I am building a 346 ls1 for boost 16-18psi, maybe spray 100-150 later on. I know the crank will be fine but what rods and pistons(dome,flat top -cc?) would be adequate. I am using ls6 heads, and a blower cam from tsp, but would I benefit from buying a fast 90 or doing any additions work to the heads with boost?
Thanks Everyone, Alex
Old 11-06-2007, 05:42 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
fast 90/90 dont waste your money.if you can get the heads ported for a good price have at it.
Old 11-06-2007, 05:58 PM
wag7079's Avatar
what about ls6 intake? im just curious if there is any benfit from upgrading intake size?
Old 11-06-2007, 06:12 PM
ddnspider's Avatar
ls6,sure maybe,but not necessary.alot do an ls2 intake with a 90mm throttlebody for a cheap alternative
Old 11-06-2007, 06:26 PM
Jefro6996's Avatar
If your going to upgrade the intake swap out to a carb style intake ported to match the heads. It would be ideal for your blower/turbo setup.
Quick Reply: Boost setup ?s
