How much can a LT1 T56 handle?
I have a T56 in my 95 Z28 that is getting jacked to go in my 89 RS, i heard they are not that great on slicks at the track in stock form, but others say 450 HP or so is no problem. What is the deal? I also herd that rebuilding it is not worth it unless you go with the expensive viper output shaft and what not. True or False?
Thanks,
Zane
Thanks,
Zane
450hp is no sweat. If your clutch is releasing properly and you're driving properly, a stock trans. will be fine but a refresh of the trans, including the synchro linings is a very good idea.
The output shaft... unless you're launching hard on slicks, you're not likely to snap it. If the strip is what you're all about, then go ahead and spend the money.
should be good for 450-550ft lbs. they are rated more than the LS t56 because they were hencho en mexico.
you can use any disc for the CF plate, but i wouldnt re use a plate that i had no clue about being abused.
