HPP 3and predator are they pretty easy to understand ?
I am thinking about getting one or the other but i do not have a lot of experience with programming tools or are they pretty much easy to understand. nedd some input before i spend some cash. THANKS
Tech Fanatic
Re: HPP 3and predator are they pretty easy to understand ?
Go with a predator, if you want an easy way to tune your truck. It is ridiculously stupid quick and easy. Its got a bunch of really cool fetures like deleting torque management, adjustable rev limits, gear shifts, etc.
Definately go with the predator over the hpp3. The base tune is usually good for around 10hp or so. You can see upwards of 17 or 18hp total( in best case senario according to RWTD and some past posts) if you adjust the timing and PE(power enrichment) settings after the base tune. Care really needs to be taken when adjusting the timing and pe so you don't get too lean causing KnockRetard.
