A couple of vids of Dyno and 1/4 mile
I had my car retuned this weekend as my air fuel ration was pretty lean at WOT. This is my second pull as we were trying to dial in the ratio. The second is the quarter mile. I left the Traction contol on
Final number 418whp and 411tq
1/4 12.4
Current in sig no 1/4
1/4 12.4
You would happen to have the graph of the dyno run would you? That is the first '04 cam only numbers I've seen close to mine, but you are make alot more torque. I would like to see the torque curve and compare it to mine if possible.
I bought the cam with springs and pushrods from HPE for 799 I also put on a timing chain upgrade to be on the safe side. I did the UD pulley after the fact and the current numbers are representative of that fact. I believe I paid about 2k for the cam all the goodies install and tune.
I know I'm probably being a nuisance, but am going to be buying a catback this week and am stuck between the Bassani and Corsa touring. Do you have any vids of your car pulling away from the camera? Or drive-by vids? Thanks in advance...
No but I can make some today if you want. Don't mind the studder the car has, I am breaking in a clutch and trying not to slip it. That makes it pretty hard with a larger cam to be sure!
