Slave cylinder??
Slave cylinder??
OK. Dont know if this is going to be a dumb question or not but, i just bought a new slave cylinder and was wondering the correct procedure for installation. I know that fluid eventually travels to it but does there have to be any in it before the install or will it fill up during the bleeding??
Alex
Alex
Install Instructions
I'm looking to install a new clutch slave cylinder into my T56...
There's some pretty good install instructions for the master cylinder online, and I already replaced that. It solved my dead clutch problem for a week or so, but now it's back to no-pressure. I'm thinking it's the slave, so it's the next step.
Looking at O'reilly's
It says I need to drop the tranny to change it. Is this true? I don't want to crawl under the car until I have a plan.
Thanks!
-Dan
Thanks!
-Dan
pretty much.
you can get to it by first removing the driveshaft, then the transmission crossmember, make sure you support the tranny with a transmission jack/regular jack- keep it nice and level. you dont want to unbolt the bellhousing bolts and have the transmission dangling with no support as it can screw up your pilot bearing in the crank.
after you have it supported, take the bellhousing-to-block bolts out, wiggle and slide the transmission back using the jack, there are dowel pins that help align the bellhousing to the block so it can take some force and patience, once you have the transmission slid back enough to have the input shaft leave the pilot bearing * all you need is enough room to get your hands in between the bellhousing and block to work*
the slave cylinder is located around the base of the input shaft on the transmission, and is held in by two small bolts that are supposed to have a very light torque load on them. be sure to check and find what that reccomended torque load is, being that the slave has an aluminum housing, it can easily crack if you over torque the new one.
of course id reccomend having a small prybar, a clutch aligner(get a cheapie plastic one at napa for less than eight bucks.) a torque wrench, blah blah blah. good luck.
Since I'm pulling the tranny out, would you guys recommend replacing the clutch? Anything else like the throwout bearing or something? I've got ~67K miles on the system. If felt the clutch slip a few times over the years, but it might have been something besides a worn clutch.
