Flipped GTO manifolds on an F-body
Has any one tried using flipped GTO maniolds where the outlets would face foward above the valve covers. I was thinking with a little machining of the flanges that go against the heads they may fit. I've seen custom headers this way but was looking for a easier solution
I want to leave the cats in the stock location with 2 gt35's and run the downpipes for each turbo where the stock cats are.
I think they will work... I am going to try and see if I can use them on my GTO and still have A/C and keep everything in the stock location. Us GTO guys have alot more room to play with on the side.
Might want to also talk to ls1turbo about selling there little adapters they have on the GTO's cause there using the stock mainfolds with the adapters.
I got some pics I will post later. On a GTO its going to be hard becuase the frame rail is close. I should be putting the motor in today. I know there is someone who had a GTO header on the passenger sided and a fliped truck manifold on the driver side and running a single like that.
