needs some help
Old 11-17-2007, 05:32 PM
00silverGTP's Avatar
Default needs some help
ok i am having some issues with my clutch. its a stock clutch with 80k miles. clutch grabs fine, but after a wot run it won't go into gear or it gets stuck in a gear. the pedal gets soft. I just put a new master in it and it does the same thing. I have bled it twice. do i need to bleed some more? or a new slave?
do i have to take the tranny out to replace the slave?
Old 11-18-2007, 08:52 AM
anyone?
Old 11-18-2007, 05:31 PM
_JB_'s Avatar
Yes you have to take the tranny out to replace the slave. Can't help you on the other part.
Old 11-20-2007, 04:45 PM
no has any ideas?
whats the effects of a failing slave?
Old 11-20-2007, 04:57 PM
98TADRIVER's Avatar
sounds like you need a new slave cylinder. here's a really good write up by Ranger on clutch care and problems associated with a shitty slave - http://www.rangeracceleration.com/Clutch_Care.html
