Tranny grinds shifting to 5th gear WHEN COLD. What gives?
Since we've been getting colder weather my M6 has starting grinding when I try to shift to 5th. If I drive the car for 10-15 minutes then it will shift fine. I'm assuming the transmission just warms up. So my question is, why can I not shift into 5th, without grinding, when it's cold?
Me too with the 5th........ Same symptoms. Only started since it's been getting colder out and after some driving it's back to normal. Deff weird
Or maybe a part is on it's way out?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I think that's what I'm leaning towards too. I changed the slave cylinder fluid, because it looked like oil, and this weekend I'm going to change the tranny fluid just to see if that helps.
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
ya thats exactly what it is.... i just did a heads and cam swap on my car and the tranny/clutch are dying does the same exact thing regardless of temp.. Do you hear any type of bearing noise coming from the console?
I've seen several cases where cold weather effects the shifting issues or clutch issues with standard transmissions . I would start with a fluid change and bleeding the clutch . If that does not fix it , you will probably need the transmission looked at or replace the slave cylinder depending on what the issue is .
