Where to ground gauges inside
I understand there is a ground location near the front kick panel on the driver's side. Where exactly is it located? If I have to remove the kick panel, how do I do that? Is there a better ground near that location?
This is for some Autometer gauges I am installing.
Thanks for the info.
I don't suppose there is anything on the driver's side I can use, is there?
Would rather not run a wire all the way over to the passenger side if I can avoid it.
