can you bypass the vats?
i just want to get my engine runnin and it still has the vats programmed into the computer. if i just run the fuel pump off an igniton hot source, it should run no? i thought the vats justkept the ecu from turning on the fuel pump, or is there more to it?
im going to keep the vats. imgoing to build one of those signal generators, i just wanted to get it running. today im just runnin my fuel lines, i probably wont get to try to fire i today. i just came in the house to call advance to have them deliver some parts.
