454ss gears??
Old 11-24-2007, 01:46 PM
blk496ss's Avatar
Default 454ss gears??
so im tryin to find out what gears i have in my truck stock it came 3.73 but i the 2nd owner but i got a buddy with the same truck with same gears n he can cruise at a higher speed on the high way than i can so im starting to think i have 4.11's? so my question is if it came with 3.73 would it have a good amount of clearance in the case or would they barely fit?? here is a pic of mine
Old 11-24-2007, 02:19 PM
Jays00ss's Avatar
divide your ring gear teeth by your pinion gear teeth that will give you your ratio.
Old 11-24-2007, 02:26 PM
purdueranger's Avatar
Another way to figure it out is... spin the tires 1 rotation and count how many times the drive shaft spins and you have your gear ratio.
if the d-shaft spins 3 an 3/4 rotations then you hve the 3.73 and if it spins just over 4 times then you have 4.10s and so on.
Old 11-24-2007, 02:32 PM
Jays00ss's Avatar
Yes another good way if your pan is not off!!
Old 11-24-2007, 02:45 PM
blk496ss's Avatar
yeah i did the turn the wheels thing already n it made 3 3/4 thanks man i jus toook of the cover to take a look n check a diff way
Old 11-24-2007, 06:36 PM
what size rubber do you run on and what does he run? This will affect RPM too.
Old 11-26-2007, 07:55 PM
blk496ss's Avatar
yeah i run 17s he runs stock size 15's
