Drag Racing Tech
Mini Tub/full Tub Weight Reduction Is In !
Old 11-26-2007, 11:56 AM
chrismorales75's Avatar
Default Mini Tub/full Tub Weight Reduction Is In !
The numbers are finally in.
16" MINI TUB: metal removed 49 pounds, weight of metal to box frame and tubs 15.5 pounds.
Total weight savings with 16" mini tub 33.5 pounds.
17" MINI TUB: metal removed 56.5 pounds(includes part of the panhard bracket removed), weight of metal to box frame and tubs 16.5 pounds.
Total weight saving with 17" mini tub 40 pounds.
17" FULL TUB: metal removed 74.5 pounds !
Weight of metal and tubs 21.5 pounds.
Total weight savings with 17" full tub 53 pounds
NOTE: FULL TUB weight does not include metal hump over gas fill hose so even more weight could be saved with it removed.
Hope you enjoyed the post
Quick Reply: Mini Tub/full Tub Weight Reduction Is In !
