Tapping oil pan for oil lines
Old 11-29-2007, 09:31 PM
Sk8runeg's Avatar
Default Tapping oil pan for oil lines
I am going to be installing my trubo setup in about 3-4 weeks and there was something I was wondering...
I am going to tap the pan for the feed line near the filter at the block-off plate, and the return to the top of the pan.
Do I need to drop the pan to do this? Or will the shavings be too many and ruin something?
Is there a way to do it without dropping the pan?
Thanks
-Scott
Old 11-29-2007, 09:37 PM
LS1Tech Sponsor
hellbents10's Avatar
Over fill it with oil so the shavings run out when drilling and taping.
Old 11-29-2007, 09:45 PM
Darren P's Avatar
on my first install I used grease in the drill and tap, cleaning it out at least 10 times and putting new grease on each time, then I drained the oil and squrited 4 cans of carb cleaner through the hole with the car tilted toward the drain, then I took a shop vac and duct taped a 1/4 inch peice of brake line bent in a slight angle and vaccumed the entire oil pan out through the drain hole and the new hole that I had tapped
the next 3 or so times that I changed the oil it had a slight amount of shavings still in it
this time I dropped the pan and washed it after I was done
I will do it ilke that every time I do it again
Old 11-29-2007, 09:57 PM
RooRnZ28's Avatar
is dropping the pan a pain?
Old 11-29-2007, 10:57 PM
Sk8runeg's Avatar
Never done it but I'm pretty sure you need to lift the engine a little...
I like the overfilling it idea :-)
Old 11-29-2007, 11:13 PM
ZL1Killa's Avatar
EPP has done it. check out their build with Scott Hewitts SS and i love those guys at EPP
Old 11-29-2007, 11:18 PM
Willem @ Fuel Injection Concepts's Avatar
put a good slab of grease on that drill bit/tap and you will be good..
Old 11-30-2007, 12:24 PM
moehorsepower's Avatar
I believe you can purchase a Punch from Vortech that is specifically for this purpose that eliminates drilling of the pan, You just punch it then run a tap through it with a lot of grease to catch what little shavings the tap will create. I used this on my pan with no problems, A friend of mine had the punch...
Old 11-30-2007, 12:26 PM
Reject's Avatar
wont that crack it or something? got a pic of it?
Old 11-30-2007, 12:30 PM
Hugger Z's Avatar
I dropped my pan when I did mine. But it was easy at the time because I had dropped my k-member to install the tubular one. If you are not dropping the k-member you need to raise the engine up to get clearance to drop the pan. And that can be a pain as you need to remove the engine mounts so the engine will move enough.
When I tapped mine with it off there were plenty of shavings to clean out. So I am glad I removed it. I even unbolted that splash guard and found some more had gotten under there and not come out when I sprayed it down with cleaner.
I have heard the grease method before but am not sure how reliable it is or not. There were a lot of shavings when I did mine. Just keep an eye on it and if you get a lot of shavings, clean and reapply the grease.
Old 11-30-2007, 01:15 PM
Darren P's Avatar
that won't work on a cast pan
it is for the old school small block with the stapmed steel pan
Old 11-30-2007, 03:13 PM
RealQuick's Avatar
Exactly..
Old 11-30-2007, 06:09 PM
I think you'd have to be one built **** to be able to make a hole in an ls1 pan with a punch
Old 11-30-2007, 07:19 PM
Scott(382-$T$)'s Avatar
EPP
Old 11-30-2007, 08:12 PM
EPP
EPP's Avatar
Thumbs up
Originally Posted by Scott(382-$T$)
EPP
Scott, you still need to change your name. lol Bob
