LS1 4 inch bore?
LS1 4 inch bore?
I have to pull the engine due to a valve breaking off my head and destroying a piston. Need some info about boring the stock block to 4.0 while I have it out and disassembled. Can it be done and will the cylinders have to be resleeved? Also while I've got it out can you do anything to the stock crank to increase the stroke to about 4.0 without buying an aftermarket crank?
LS1Tech Co-Founder
Re: LS1 4 inch bore?
You can only go up to .010 with a 2000-2002 block. A 4.000 bore would require resleeving.
Stock crank is 3.622 and you can only offset grind maybe .200 so can't get to 4.000 stroke.
http://www.agostino-racing.com/
Give them a call. They can help you on the bore. You would have to get it resleaved to an all bore block, in order to get a 4.0 bore.
Yes, you can offset grind the crank to get more cubes. 3.72 will be your limit on the stroke, with the stock crank.
http://www.aera.org/tech/cube_calc.html
To figure out the cubic inch you can just go by this simple formula.
.7854 x 8 x Bore x Bore x Stroke = cubic inch
If you need pistons give me a call or you can call one of our dealers like Thunder Racing, LG Motorsports, Futral Motorsports or Agostino Racing.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
<small>[ February 03, 2003, 11:20 AM: Message edited by: DIAMOND ]</small>
Thanks,
Chris Gelineau
Diamond Pistons
Correct me if i'm wrong guys, but it my understanding the size of the 6.0 liter crank is identical to the 5.7 LS1 crank and as such, either crank is interchangeable in either block.
MTI 427 C5 Roadster,
ps-Diamond Pistons-That is by FAR the BEST AND EASIIEST FORMULA i have ever seen for figuring out CID of any engine! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I'm looking atmy GM HighTech Perf. Magazine and the numbers from GM are that the stroke and rod length are identical between the 5.7 ls1 and 6.0 lq4 engines, the only difference is the bore size and heads(which has a decreased comp. ratio).
