header clearence
Old 12-01-2007, 11:44 AM
LTLRDSS's Avatar
Default header clearence
i just did a qtp header install and it dsn't rub anywhere untill the engine torqes like when you start to give it gas then i vibrates alittle and goes away. any ideas on how to get better clearece, i was thinking about loosening all the header bolts and putting a shim where i might be rubbing and torqe the bolts back, but im not sure if i take the shims out will the header spring back to where it was. any ideas would be great
Old 12-01-2007, 11:49 AM
01CaMMMaro's Avatar
poly motor mounts
Old 12-01-2007, 11:54 AM
Yahelou's Avatar
if its vibrating against the k member, u can grind it down a bit without any harm.
Old 12-01-2007, 02:02 PM
EvilBLK02TA's Avatar
you sure its your headers and not your y-pipe?
Old 12-01-2007, 04:07 PM
Senior Member
Country Boy's Avatar
Another $1200 setup that hits something... woah....
