camshaft
camshaft
i am going to be upgrading my valvetrain this winter and i was wondering what is the biggest cam you can run without worrying about interference. i was thinking about running a comp custom grind cam- 231/237 .589/.595(I/E) 112LSA. would i be able to run this without modifiying the bottom end? i would also be upgrading the stock springs to the comp921's with hardened pushrods and new comp roller lifters and 1.7 comp roller rockers.
yes that cam should clear but I would measure it if I were you, there are write ups in the internal section. The T-Rex (Thunder Racing) is supposed to be the biggest cam that will fit, the Vengeance Vindicator, and MS4 (Texas Speed) are all also the "big sticks" for LS1s. If it's a street car you probably don't want a cam that big, the one in your post is medium/big depending on your tolerance levels.
i'm not going with the trex i just wanted to know how big it is in comparison to the comp cam i am looking at? would i be able to run the comp cam with stock heads for now?and upgraded intake?
