im having clutch and pedal problems i need help plz????
Old 12-08-2007, 12:52 PM
hnaskoct's Avatar
Default im having clutch and pedal problems i need help plz????
well ive just put a new slave and , master in and i have a stock o'reils clutch in with about 700 miles on it well i had it in there before i installed the new slave and master... i have to pump the clutch several times before i could put it in first and i have to pump it to go to the other gears and when the car is off i pump it and the pressure builds up fine in the pedal but once the car is running the pressure isnt there and the car would start rolling if its in gear... need help real bad
Old 12-08-2007, 02:15 PM
TheLS1Kid's Avatar
Sounds like you need to bleed it.
Old 12-08-2007, 02:42 PM
hnaskoct's Avatar
i have bled it a whole lot
Old 12-08-2007, 03:09 PM
TheLS1Kid's Avatar
Did you bench bleed the master and slave before you put them in the car?
Old 12-09-2007, 12:08 PM
hnaskoct's Avatar
no i didnt bench bleed it but i still have bled it with the mity vac and from the bottom
Old 12-10-2007, 08:57 AM
hnaskoct's Avatar
ttt......
Old 12-12-2007, 10:59 AM
hnaskoct's Avatar
ttt..............
