How to tune med. load?/Edit
Ok i got the part throttle down. And the full throttle down. But when i just want to hit the gas a little and speed up while in 5th or 6th i get allot of kr untill my rpm's come up. But while im just crusing everything is fine. So which table will tune for moderate load?
Location: Richmond, VA Where fast cars, well......are hard to come by.
Re: How to tune med. load?/Edit
That's just a lot of load. The valve is open for a relatively long time and allows a lot of air to get in, creating more pressure. You can pull timing the same way as any other time, it would probably e the middle left area of the timing table. You could also richen up a small maf freq window if you can find what freq it constantly is at.
Awesome wheels by the way.
