LS1edit worth it on internally stock car?
Old Jun 19, 2003 | 03:21 PM
u8dusst's Avatar
Default LS1edit worth it on internally stock car?
Just wondering if its worth it to shell out the dyno tuning time for LS1 Edit on a full bolt on car. If its possible, Id like to squeeze out 360 RWHP internally stock.
Old Jun 19, 2003 | 03:32 PM
AsianIce25's Avatar
Default Re: LS1edit worth it on internally stock car?
Definitely not wirth it. What are they going to do to make you make more power and what for the $500? Maybe delete some codes you and then advance the timing a bit. Ive seen it where they advance it too far, and the computer pulls more timing out from knock then you started with. Id wait until you get a cam and/or heads.
Old Jun 19, 2003 | 04:16 PM
Cal's Avatar
Cal
Well you can fix the speedo if you've changed gears, reprogam the fans if you've changed t-stats, kill the CAGS if you have an M6, and remove the speed limiter if you want to go over 162mph (good for bragging rights if nothing else.)
Old Jun 19, 2003 | 04:28 PM
u8dusst's Avatar
You can kill CAGS with LS1 Edit? I didnt know that. I have a 160* t-stat in my car right now, so what temp would be the best to set the fans at? I really dont know anything about this tuning stuffs.
Old Jun 20, 2003 | 01:01 AM
SScam68's Avatar
Contrary to Asianice
tuning will get you a bit more power with some of the above mentioned editing. $500? If I recall thats for practically unlimited tuning, depending on the tuner. So if you add and intake and want to check things you can go in. If you add headers then you could go get the car tuned for that.
Basically its an upfront price. The best thing to do is find a tuner near your, preferably a sponsor, and ask about it. Doesn't hurt.
Old Jun 20, 2003 | 06:07 AM
TaTommyWS6's Avatar
Sure it's worth it. Headers alone should really be tuned in...
There are plenty of parameter tweaking that would help even a completely stock car:
If you have an A4 change the shift points and firmness.
If you have an M6, disable cags.
Remove Torque management.
Lower fan temp on/off setting.
Add a little timing at WOT.
(Kill than damn speed governer)
The list goes on and on...
And as you do more mods, which you WILL, you really need a way to tune your car's A/F.
Good luck.
Tommy
Old Jun 21, 2003 | 02:43 PM
Jpr5690's Avatar
id say yes you will benfit form the tweaking avaible from ls1 edit espaically if you have long tubes but its moot if its worth $500 if you plan on going further your gonna need it anyway but if your pritty much done you'ld be just a good buying a used predator for like 1\2 the cost. also if your auto tranny a tc would result in more gain but then you need ls1 edit sometimes to make that work properly. and like some have said tunning from headders will net power. with longtubes tunning is almost a must (IMO)
Old Jun 21, 2003 | 06:33 PM
DEEZ98Z's Avatar
A freind of mine got 15rwhp out of a stock internal car with edit I say go for it
Old Jun 22, 2003 | 04:50 PM
The Kiss Guy's Avatar
I had mine done a couple weeks back, alot of things adjusted including fan temps. However, mine was $400 and only includes one return visit. It was done with me driving the car instead of using a dyno.
I am also disappointed in my first dyno run from Friday. So don't know what's up.
http://thekissguy.netfirms.com/graphs.htm
Old Jun 23, 2003 | 03:03 PM
Kansas 99z28's Avatar
you can get rid of the CAGS with a $30 part from www.jegs.com. part #555-10500 for the jegs part or Jet performance make one for $32 part #530-155-0100
Old Jun 24, 2003 | 01:38 PM
67ls1CamaroProject's Avatar
For $1.00 you can get rid of CAGS with a resistor from Radio Shack.
Old Jun 26, 2003 | 01:26 AM
absolut_speed's Avatar
I picked up 18hp on a bolt on car with tuning.
Old Jun 26, 2003 | 08:52 AM
CamaroCain's Avatar
There is a post made, I believe in the Drag Racing forum on this board by a "Larry" about tunning, you should read it. My car is SI and I plan to do tuning in the very near future.
