Would I want a longer duration on a stock cubed H/C motor?
I'm really considering the Comp 228/228 .588/.588, but what I'm wondering is, is the 228 duration gonna make my power band really peaky? I was thinking about running this cam on a 111 lsa and a 108 icl. I'm trying to keep from spinning the stock bottom end too high, but I still want to make good mid-range and top-end power. Radical doesn't bother me one bit, but then again, I don't wanna be swapping springs all the time either. I'll be running the Comp 987's, and I'll also be replacing the lifters with Comp "R" pieces.
What do you guys think? This cam will be going along with a set of TEA St.2 5.3's. Also, I don't wanna have to worry about P to V clearance. Any opinions?
Re: Would I want a longer duration on a stock cubed H/C motor?
Why not? Go with a 232/.588"-110. This is the cam I've been dieing to get in my ride. The motor will eat it up- choppy idle, but the lift won't chew up springs and the LSA will kepp the powerband down to a reasonable level- below 6800 rpm. This would be even better on a set of heads.
I CANNOT wait to try this combo out. I feel very strongly that this will put out over 450rwhp on TEA stg III heads and will not kill my bottom end.
I HIGHLY suggest a ported oil pump of some kind, and PLEASE make sure you check P/V clearence.
The oil pump will be replaced, I just forgot to mention it. Also I'll be replacing the timing chain with a Rollmaster piece, and upgrading to the LS6 intake.
As far as the choppy idle, I could care less about that. As a matter of fact, the choppier the better!
Anyways, I never really thought about a 232, but I have considered a 230/230 .592/.592 on a 110 lsa.
i have a 234 238 600 591 on a 110 that will be coming out of my car next week. inetersted?
where did it peak and what kind of numbers did it put down? What mods are done to the car?
436 rwhp @ 6300 408 ftlbs @ 4600. all bolt ons are on the car plus this was done through a 12 bolt with 4:30s. it was also on a conservative tune since i spray every now and then.
LS1Tech Premium Sponsor
We sell alot fo the TSP228 cams, with decked heads you will definately need to cut your pistons with decked heads. I know this because Trevor had his 228 on a 111. As far as the 232 cam, we also offer a 232/228 setup that I think has potential to make some good hp. If you want to get really crazy we have a 231/237 cam with 598/595 lift on a 112
We check piston to valve on every car with a cam bigger than a 224R, better safe than sorry when it comes to p/v clearance
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Thanks for the input Jason. P/V clearance will definitely be the first thing checked before installing the cam. I just want to go as big as I can without having to flycut the pistons.
Another thing Jason, on that 231/237 cam, why is the duration a traditional split, yet the lift is a reverse split. I'm not quite sure I understand the advantage of that.
But if the intake on our cars are the choking points, wouldn't you want the duration on the intake side to be longer than the exhaust?
Keep this in mind also.... all the GM designed cams I've seen (who designed the engine no less) are traditional splits from the stock cams all through the racing spec'ed ones.
What the reverse split does basically is it gives some of the benefits of a large cam while keeping the driveability of a smaller one with the shorter exhaust duration.... it's more of a compromise than an all out power producing cam IMO.
Isn't scavenging going to be a problem with the larger split cams.....there has to be a point where too much of a split will start losing power.
from what i've been told by Mark over at comp when i ordered mine, the reason we dont see much bigger splits than what we do is because of the intake to exhaust flow ratio. we have great heads on our motors and we dont need a whole monster of a cam to take advantage of them. stock heads for example flow (roughly) in the 230's on the intake and 200's on the ex. that puts the intake at about 86% of the exhaust. you really dont need to split the cam any more than 86% I/E wise to keep more of a flow balance in the motor. now take a look at some of our ported heads that make it closer to 92% i/e flow ratio, and you start to see why more and more single patterns as well as reverse splits are being used to keep tq numbers up there. you dont need nearly as much exhaust flow as you do intake because of lesser volume of the spent gasses. make sense?
this is why our cam patterns are so signifigantly diffrent than the LT1, SBC and other conventional small blocks. this same ideology applies to other 15* and 18* cyllinder heads too. hope that makes sense. i think i got lost in there somewhere too.
