Supercharged Six Speed....
You need to add a few more details to your post, as it is pretty vague. Most people don't have much blowby, what is your combination and where are you seeing blowby. Bob
well i have an ati p-1sc procharger with stock fuel pump and in line fuel pump,twin intercoolers, and 42 lb injectors. running about 7 psi boost with six rib belt and I'm getting blowby out the crankcase. I bought a oil cap breather thinking it would help. don't think it did. when its just sitting idle you can see the blowby coming out the breather.
Any ideas would help....thanks
Is the motor stock? If so this may be another reason as stock motors and boost aren't a good combo unless you are looking for a rebuild on purpose.
If the motor is built and still in good shape, then you may just need more ventalation as one small breather is almost never enough.
Try this.
http://www.jegs.com/webapp/wcs/store...0002_248712_-1
Really, I would only purchase the Nipple and Check valve. Dont use standard heater hose because the oil will break down the material. Have these welded in close to your header collector and it will help with ring seating. Reduces crankcase pressure throughout entire rpm range for increased piston ring seal, reduced intake charge contamination, and fewer oil leaks.
Breathers will smoke at idle if there is temperature in the motor. Also, if one bank is open and the other is recirculated, it can cause issues.
Try this.
A similar setup to this comes in HPP's turbo kit and others as well.
Moroso sells just the nipple -
and the check valve -
And you can run tubing (I like aeroquip push lock fuel line because it doesnt break down) from your valve covers to the checkvalve(s)/nipple(s). You weld the nipple at an angle where it will pull vacuum clearing the system of crankcase pressure and helping with a ton of oiling issues ESPECIALLY on boosted applications. The actual location of the nipple is somewhere in the exhaust, usually close to the header collector. I like putting them just after the collector because If you ever want to change setups, your headers arent altered that might skew someone from buying them.
Just FYI, this WILL NOT add any sort of smoking or anything from the tailpipes.
the car has 63000 miles and i noticed an oily film on the intake when i bought it in april of 07. so i purchased the breather and thats when i noticed the blowby.
