LS1 Rx 7 FC... Front Accesories
I have an 88 rx 7 I am doing an ls1/t56 swap. The motor is from an 04 gto, it has a crank pulley/balancer but no front accesories. I am am only going to run AC,Water pump(obviously), and an alternator. I will be using the grannys mounts. What do I need to get accesory wise. Will camaro and firebird brackets and accesories work? Or do I need to go with the GTO stuff, I searched but had trouble finding any real answers. I don't have a pcm and harness yet either, I am assuming that may be a factor. But anyway any help would be much appreciated! Thanks guys
Chris
Chris
Yes the cambird accessories will work - not sure about the GTO.
Search here - http://www.v8rx7forum.com/
Ok thanks, I am on the v8rx7 board too... can't seem to find much by searching. I guess I really just need to figure out if the gto balancer is the same as the cambird?
I see you have an 88 vert, I do too. Got any pics?
