Got the NX kit up and running! Couple ?'s
Spraying 100 shot on top of my h/c package. Seems to pull pretty good. Hopfully ill hit the Dyno and the track within the next month or so. I also installd a Walbro 342 fuel pump and 30# injectors (since i found them for $100) Still need to do a little more tuning on the Edit. But getting about 25* timing and Very little KR. (I always have KR problems d*** 98's) I'm just going to up the WOT a couple % to be safe.
Question #1 What is the best bottle pressure with the N/X wet kit Shark nozzle setup? I hear anywhere from 900-1100??
Question #2 With stock head bolts/gaskets/bottom end should i attempt the 150 jets?
I ran 11.50's n/a. I just hope for a 10 sec. slip. It feels a little more sluggish with the Tr6's gapped down to .38 I guess that's part of the game huh?
Restricted User
Re: Got the NX kit up and running! Couple ?'s
1-I go with 1050, produces the best et's for e.
2-Yep, you can. Its up to you, but I had a internal stock set-up w/mods listed and ran 150shot-and it feels good.
OK, so you got it going. So what.
August 2nd EFI shootout at Centerville. $100 each entry for some private action (invite your friends). Winner take all.
No juice. Motor.
No juice. Motor.
I'll run you all motor and see what happens too.... You can bring your slicks...I'll just run drag radials... All I have is a little cam and some headers...
Awww. And here I thought we could just have some fun. Sounds like it would be easy money for you, Tim. Maybe 9.8 would, and maybe it wouldn't. I guess noone wants to find out.
Maybe I'll switch to brackets...after last Saturday, the car is ready...
BTW, Tim...did you switch the rod bolts to ARP's? How's your wife's car doing...in good working order? What does the military teach you about contingency planning?
Some people want to race street cars some want to race race cars. Untill then ill drive to the track and hand out some butt whippins and drive home.
P.S. The Avalanche is running fine. Why do you ask want to run it against your tow rig?
