F1R or 76mm turbo
F1R or 76mm turbo
If both are air to air intercooled which would be better for a heads up class. The LS engines have to use oem heads. What kind of power could a racing fuel no meth set up make? Nos SBC rule the class now and run 5.60 5.70. Can a F/I LS engined car compete? The SBC cant use 18* heads. Car will have to weigh 3300 with driver.
Where is this class located
the NMCA class is limited to a d1sc or a 72 mm with 550 lift cam and 220 runner heads and many of those cars have gone low 5.80 and high 5.70 in the 1/8 and 8.90's and 9.0's so with a f1r or 76mm 5.60s should be possible
I am building a 6.0L for the NMCA street race class at this time the class rules changed from 72mm to a 70mm think that i should be able to make 1050hp and run low 9's high 8's
I would run the 76mm if it was me
same tires that are allowed in the Street race class
wish was closer to IL like the NMCA but lots of traveling sound like a fun class
1320.com Mike Fantena runs in the 8.99 on an video on 275 bfg's 1.3 something in the 60 foot with cheap 355cu and precision 72mm turbo check it out
Good luck on the build what is the class record
I believe a 5.67 at around 125-6. I think it can be done also. Here is a link to the rules the class is True Street.
http://www.texastrueten5.com/
