slp mass air and a dry kit
Hello all I bought a 85mm slp b/c it was cheap and i am wonderig if it would be ok to spray through it. It increases timing like 1 or 2 degrees. Also how high can I go without it causing me problems, but if I need to go with the stocker I will.
Thanks
Thanks
Re: slp mass air and a dry kit
for what your doing theres no reason to descreen it and by descreening it you may get problems cause this allows the air to flow turbulently past the sensor and does not allow for accurate readings slp does not reccomend descreening the maf unless you are pushing more than 650 hp from what i here but then again some do it and have no probs at all i can just say theres a risk involved and no gain for your setup (IMO)
