Switch panel wiring, hows this look?
I have a moroso fused switch panel and im going for the cleanest looking and shortest wires possible for my switch panel/relay board. I came up with this to try to keep the clutter down. Im not to crazy about running that much current to the switch, even though its not really going through it. Im doing this for my fans and lights too, just drew this up for the fuel pump real quick. What do you think?
This is the panel.
This is the panel.
Save the manuals!
Depends on what you want your indicator light to tell you. Do you want it to tell you that your fuel pump is actually getting juice? If so, it won't do that.
In your diagram, the light will only tell you that your fuse is not blown and your switch is working. If you have a relay problem or a wiring problem downstream from the switch, your indicator will still be on.
